Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
Corolla
Drivetrain
Transmission
Gear Selector
Stuck
1992 Toyota Corolla Gear shift Stuck
1992 TOYOTA COROLLA
149,000 MILES • 4 CYL • 2WD • AUTOMATIC
TOPAZ15
MEMBER
1 POST
Gear shift stuck in park, unless press override lock button. why? what needs to be corrected?
Nov 3, 2009 at 11:49 AM
MMPRINCE4000
Experienced Mechanic
The shift lock system has failed, there are a number of components that may be faulty.
Remove shifter handle and inspect plastic wedge that allows you to depress shifter, it may be worn out.
Also shift lock solenoid may be faulty.
Nov 3, 2009 at 10:06 PM
Add image or video
Ask a new question
Engine won't start
Check engine light
