1992 Toyota Corolla fuel filter
KINGSLANDM0214
Engine Performance problem
1992 Toyota Corolla 4 cyl Front Wheel Drive Automatic
where is the fuel filter located. underneath, or in the tank
Jul 9, 2009 at 11:09 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Should be under hood, driver side, rear engine area, passenger side of master cylinder, mounted in fuel line
Jul 9, 2009 at 4:28 PM
MMPRINCE4000
  • 8,548 POSTS
To add to what Blue said:
Best way to change it is to remove drivers wheel and stone guard, and access through the steering rod hole in frame.
Lower fitting is a double inverted flare, use a line wrench and spray some PB Blaster on it. Be very carefull not to round off the nut.
Also take the charcoal cannister off from above for better access.
Jul 10, 2009 at 2:27 AM
