1992 Toyota Corolla Engine stumbles on acceleration
110,000 MILES • 4 CYL • FWD • AUTOMATIC
TOJOWILLIAMS
History: Car sat for many years. Had to replace the fuel pump, clean the rust from the fuel tank, rod out the fuel line, replace the fuel filter twice, added injector cleaner, replaced distributor cap/wire and rotor, exhaust manifold, catalytic converter, map sensor. Currently when I floor the accelerator, the motor sputters like it isn't getting gas and loses power. Driving easy on the pedal and it does ok most of the time. Haven't put it on a scanner but i'm tired of changing parts. Please help.
Nov 12, 2008 at 1:17 PM
  • 75,988 POSTS
Test throttle position and mass aiflow sensor
Nov 12, 2008 at 1:19 PM
