1992 Toyota Corolla engine problem
GEET
  • 34 POSTS
Engine Mechanical problem
1992 Toyota Corolla 4 cyl Front Wheel Drive Manual
hi my car engine is 20 years old. it has started consuming oil. i add oil treatment in it. now am asking is it ok to rebuild the engine or change it with a second hand one. cost of both is the same. my engine was rebuilt 2 times. it has high idle and oil seeps through spark plug cylinder at bottom even i changed head oil seals. it consumed half the oil in its pan. will the change improve fuel economy? it does 60 km per gallon now.
Sep 2, 2010 at 4:16 AM
MMPRINCE4000
  • 8,548 POSTS
I would replace with used engine.
You can find what are called JDM engines on ebay.
These are Japanese engines, usually low miles, taken from Japanese cars and imported to U.S.
I replaced one with a JDM engine 3 years ago and it still runs good, uses NO oil.
Sep 3, 2010 at 12:11 AM
