1992 Toyota Corolla Cliking Noise on TUrns
423,300 MILES • 4 CYL • FWD • MANUAL
RUFQUI
Why does my front wheels produces clicking sound on driving turns at more than 25kph? say click click click click click click click then stops on driving straight?
Sep 18, 2010 at 12:32 PM
DSPLC
  • 220 POSTS
You need a new CV axle shaft to the side where the sound is coming from. Front left or right side
https://images.2carpros.com/forum/automotive_pictures/89255_drive_shaft_1.jpg
Sep 18, 2010 at 1:33 PM
TEXASB22
  • 11 POSTS
pretty easy job first time working on my corolla and i had to replace both axle right was easy left needed a slide hammer to get it off. but after i replaced mine heard weird noises so be carefull. still havnt figure out what the other noises were coming from. and also if you have the money check the bearings i also did those while doing the 2 axles. both axles like about 45$ each. bearins were like 49.99 each side takes about 4 to 6 hours to fix if its first time.
Oct 13, 2010 at 9:08 AM
TEXASB22
  • 11 POSTS
be carefull not to break the seals inside the trans. forgot to add that think i did and now its making another noise and its weird. even though it is only going to cost me 10bucks each to fix still a hasselle
Oct 13, 2010 at 10:36 AM
MMPRINCE4000
  • 8,548 POSTS
Check under the car for two trans. drain plugs, if there are two then one is differential, and when you change axles, you need to add fluid to differential.
The auto has a differential, and if you do not refill, it will eventually sieze the diff.
Oct 14, 2010 at 1:50 AM
