You can remove the interior panel, then remove the outer door handle. Take it to a locksmith and have a new key made or the lock cylinder repaired.
If equipped with power locks, check fuse first, If OK then remove door panel and check for 12V at solenoid, if present, then solenoid is bad.
Dec 29, 2008 at 9:58 PM
