1992 Toyota Corolla Brake system
205,000 MILES • 4 CYL • 2WD • AUTOMATIC
JOEL29M
I have a 92 Toyota corolla, after 10 minutes on the road my brake calipers stick 15-20 minutes then loosens up. I replaced the calipers this weekend and the problem is still there, could it be the master cylinder or something else?
Oct 18, 2010 at 11:49 PM
MMPRINCE4000
  • 8,548 POSTS
MC or clogged brake lines, first flush entire steel lines system, then refill with fluid.
Also make sure caliper slide pins are not sticking.
Oct 19, 2010 at 1:44 AM
