HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Toyota
Corolla
Exterior Light
Brake Light
SPONSORED LINKS
1992 Toyota Corolla brake lights
KEEPMENMIND
MEMBER
1992 TOYOTA COROLLA
Brakes problem
1992 Toyota Corolla 4 cyl Two Wheel Drive Manual
my brake lights won't go off
i found a black round piece on the floorboard
under the brake peddle
where does it go?
Friday, January 22nd, 2010 AT 12:58 PM
BLUELIGHTNIN6
MECHANIC
Most likely that is a spacer for the brake light switch. Switch is located on the brake pedal bracket below driver dash
SPONSORED LINKS
Friday, January 22nd, 2010 AT 4:20 PM
MMPRINCE4000
MECHANIC
As blue said, that is EXACTLY what it is.
If it falls off, the brake light adjustment will be off and lights will be on all the time. You can adjust switch to compensate.
Saturday, January 23rd, 2010 AT 8:24 AM
Please
login
or
register
to post a reply.
Related Brake Light Content
1992 Toyota Corolla
Yes When I Step On My Brakes One Brake Light Doesn't Work
Asked by
tonyss88
1992
TOYOTA COROLLA
VIDEO
How to Replace a Brake Light Toyota
Instructional repair video
GUIDE
Brake Light Repair
The brake light system in your car is used to help alert follow drivers that you are about to slow down, this system consists of to lower brake lights on the right and left...
Brake Light Turn On When I Turn My Lights On
I Have A 91 Corolla And When I Turn The Lights On The Brake Lights Light Up, Also When I Hit The Brakes When The Light Are Turned Off The...
Asked by
cliffmunk3
1 ANSWER
TOYOTA COROLLA
Brake Light
I Have A 2000 Toyota Corolla Automatic And About 85,000 Miles. The Brake Light Came On In The Dash Board? What Does That Mean?
Asked by
Vanissa
TOYOTA COROLLA
1990 Toyota Corolla Battery And Brake Lights
Hi, My Brake And Battery Light Keep Coming On At The Same Time. What Does That Mean? Thank You!
Asked by
alleycatsyo
1990
TOYOTA COROLLA
1990 Toyota Corolla Help
I'm Having The Strangest Problem, When I Hit The Brakes My Dashboard Lights And Front Park Lights Come On? Also When You Turn The Lights...
Asked by
darklionjm
1990
TOYOTA COROLLA
VIEW MORE
SPONSORED LINKS
Brake Light Replace
Brake Light Bulb Replacement
Online car repair manuals
