PICKED UP A COROLLA WITH WHAT WE THOUGHT WAS A BAD TRANSMISSION, GOT IT HOME CHARGED THE BATTERY AND TRIED IT IT DROVE AROUND THE BLOCK I LET IT WARM UP WHILE TRYING THE A/C THEN TRIED AGAIN MADE IT HALFWAY THEN NOTHING NO FORWARD NO REVERSE NOTHING,BOUGHT ANOTHER ONE WITH A ROD KNOCK BUT GOOD TRANNY DROVE IT HOME ( SLOWLY,ABOUT 15 MILES) SWAPPED IN THE ENGINE FROM THE OTHER CAR TO THIS ONE AND THE SAME THING HAPPENED GOT AROUND THE BLOCK AND THEN NOTHING NO CHECK ENGINE LIGHTS BUT WE SUSPECT THAT IT HAS TO BE SOME KIND OF SENSOR TRIED SWITCHING WATER TEMP SENSORS FROM OTHER ENGINE STILL NOTHING SHOULD I TRY THE ONES OFF THE INTAKE?
Dec 15, 2008 at 3:39 AM
