1991 Toyota Corolla speedometer speed sensor`
VOGANNI
Electrical problem
1991 Toyota Corolla 4 cyl Front Wheel Drive Manual 235k miles
My Corolla is a sr-5 coupe. The speed sensor for the cruise control is in the speedometer. Is there a way to test it without removing the speedometer? The speedo works fine, but no cruise. The speedo speed sensor is the only item I haven't been able to test.
Oct 16, 2009 at 3:15 PM
MMPRINCE4000
  • 8,548 POSTS
Toyota may be able to test it, but it could also be a faulty brake switch or cruise servo.
I would visit the junk yard for a used servo and IP, you may get lucky and find one.
Oct 17, 2009 at 1:19 AM
