1991 Toyota Corolla Speedometer
111,875 MILES • 4 CYL • FWD • AUTOMATIC
SHERMOHAMED
Jambo to you all,
Hope all well on your end.
I have the above stated car, and i "feel" that the speedometer reading is incorrect, as before when i use to drive on high speeds, you would never feel the car clocking 120 kmp/h, until you exceed 120 kmp/h then you feel the car moving fast, now this feels when clocking only 100 kmp/h, and when you bring it to 120 kmp/h on the clock, the car moves extremely fast, feeling of clocking 160 or 170 kmp/h. I've been with this car for the past 6 years and have travelled with it long distances 14 times, and also have clocked to 180 kmp/h and know how it feels. Kindly assist.
Sep 14, 2010 at 12:57 AM
MMPRINCE4000
  • 8,548 POSTS
Most likely the lower speedometer cable needs to be changed.
They are available from Toyota for $70.
Sep 14, 2010 at 2:24 AM
SHERMOHAMED
I understand in this model, they do not use cables, they use sensors. I have seen the sensor under the hood. Can it be the sensor or the clock that is gradually dying?
Sep 14, 2010 at 9:14 PM
MMPRINCE4000
  • 8,548 POSTS
U.S. made Corolla's use cables up to 92, but if a sender is bad replace it, and clean connections.
Sep 15, 2010 at 12:30 AM
SHERMOHAMED
Okay, i'll try and check the contacts and clean them if dirty. However, i wanted to test if what i'm feeling is correct or not, what about measuring my vehicle speed with a mobile phone that has a GPS feature, can that work? Would it give me an accurate reading of the vehicle speed?
Sep 15, 2010 at 5:43 PM
MMPRINCE4000
  • 8,548 POSTS
If you could get an accurate distance and time, yes it would work.
Sep 16, 2010 at 1:55 AM
SHERMOHAMED
Right Sir,
Let me try and find a GPS device, and once done, will give you the updates. Yesterday, tried to clean some contacts, i actually followed a cable that enters on the right side of the dash, as mine is a right hand drive, i do not know the functions of that cable, but just cleaned it, and feels like it worked, am not really sure. I tried searching for an electric and sensors diagram for a 1991 ae100 through google, but could not see the link of that cable. I actually want to test it before i make any decisions on replacing any parts for the speedometer, cause here in Tanzania, mechanics are not really reliable, i checked with my mechanic, and he's never come up with such a problem, hence am a little reluctant to give him this job, therefore i wanna make sure myself first before going through any repairs. (My car is my first wife :-)
Sep 16, 2010 at 6:12 PM
MMPRINCE4000
  • 8,548 POSTS
Cable eqippped cars have a lower an upper cable that goes into firewall and the IP.
Sep 16, 2010 at 11:58 PM
