HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Toyota
Corolla
Emission
Smog
1991 Toyota Corolla Smog Test Preperation
VICTORGARCIA14
MEMBER
1991 TOYOTA COROLLA
4 CYL
2WD
MANUAL
100,000 MILES
How do I replace the "EGR" valve?
Friday, February 29th, 2008 AT 1:13 PM
MMPRINCE4000
MECHANIC
The EGR is on the intake manifold on the firewall side. You disconnect vacuum lines and electrical lines, and any exhaust hoses and unbolt it.
Toyota made two versions of this engine, US/Canada which did not have an EGR valve and CA which did.
SPONSORED LINKS
Saturday, March 8th, 2008 AT 6:01 AM
Please
login
or
register
to post a reply.
Related Smog Content
1986 Toyota Corolla Dropped Nox Emissions- But Hc's...
Okay So Here's The Deal. This Is The 1986 4a-c Corolla Engine In A Sport Sr5 Sohc. I Failed The First Emissions Test With The Main Problem...
Asked by
ISOD
1 ANSWER
1986
TOYOTA COROLLA
GUIDE
Smog Test Failure
Smog test time? When a car fails smog it means the emissions analyzed from the exhaust tail pipe is too high, there are missing emission components, or you have a check...
Egr Valve
Is There A Egr Valve On My Toyota Corolla Ae101 4afe 1993 Model Automatic Transmission
Asked by
jvw315
1993
TOYOTA COROLLA
Code Po401, Checked Egr Valve W/vacurm Tester, Holding...
Checked Egr Valve Working Fine
Asked by
George RRRR
1996
TOYOTA COROLLA
I Want To Change My Pcv Valve. My Car Engine Is 2nz-fe...
Supplier Of Toyota Parts In My Region Dnt Have Pcv Valve I Hv To Arrange It From Smwhr Else Kindly Tell Me Part Number
Asked by
fahdaslam
1 ANSWER
2007
TOYOTA COROLLA
How Do I Check My Vacurm Switching Solenoid (for My...
Have Checked Egr Valve, And Have No Vacurm Leaks Also.
Asked by
George RRRR
1 ANSWER
1996
TOYOTA COROLLA
VIEW MORE
SPONSORED LINKS
How to Read Codes
What to Do When a Check Engine Light?
Is it Safe to Drive Check Engine Light?
Online car repair manuals
