1991 Toyota Corolla Slow acceleration especially going uphi
125,000 MILES • 4 CYL • 2WD • AUTOMATIC
BAZZMAN
Hi there, my car seems to have very slow acceleration especially going uphill. Other than that it drives fine. The exhaust has been changed 1 yr ago. Before I bought it a week ago, it was very seldom driven. Any ideas?
Feb 13, 2010 at 9:59 AM
  • 75,988 POSTS
Inspect and test all the following listed below:
Oxygen sensor
Catalytic converter
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Cap and rotor
Note:If it doesn't apply disregard.
Feb 13, 2010 at 10:12 AM
