1991 Toyota Corolla Rev counter erratic
ESPRI
  • 9 POSTS
Engine Performance problem
1991 Toyota Corolla 4 cyl Front Wheel Drive Manual
Good day
My corolla's rev counter has recently started to first behave erratically and then stopped working all together. The needle will jump when starting the engine but will then fall to the bottom. During driving, it will sometimes jump about erratically.
I would sincerely appreciate it if I could know what causes this problem.
Many thanks.
Espri
Dec 22, 2009 at 5:17 PM
MMPRINCE4000
  • 8,548 POSTS
Check wiring to dist. otherwise it is most likely an intermitent open. You will have to remove IP and look at tach connection.
Dec 22, 2009 at 11:53 PM
