1991 Toyota Corolla Replacing Radio Antenna
1991 TOYOTA COROLLA
132,000 MILES • 4 CYL • 2WD • AUTOMATIC
LAFDBUF
Car has a JVC KD-LH300 radio in dash. I believe installer removed dash to install and "bolted" unit in.
I need to get to rear of unit to change out antenna wire. Can this be done under dash or by removing lower dash under steering wheel? If yes, after removing bolts from front, how does "under" dash come off?
Sep 4, 2010 at 9:14 AM
MMPRINCE4000
  • 8,548 POSTS
There are several 10mm bolts that have plastic covers. Remove covers with small screwdriver to expose bolts.
Sep 6, 2010 at 1:37 AM
