1991 Toyota Corolla Radiator Fan Inop. Engine Overheating
10,000 MILES • 4 CYL • 2WD • AUTOMATIC
ALEXPR82
Main Radiator Fan Not coming on at all. It only comes on when AC is turned on along with the compressor Fan. Radiator is brand new. There are no coolant leaks. But there is a small cut in the mifddle of the inlet hose. Could this have been caused by excessive overheating? Or could this small cut be the main problem for overheating.
Apr 11, 2009 at 9:55 PM
  • 31,937 POSTS
Hi there,
Thank you for the donation,
There is a thermo switch that turns on the cooling fan, i will locate a pic and location for you, the hose should be replaced, this may be a result the overheating.
Mark (mhpautos)
Oct 25, 2020 at 4:42 AM
ALEXPR82
Perfect! Even better . Ill be waiting for the picture.
Thanks
MMPRINCE4000
  • 8,548 POSTS
Coolant fan switch is below the distributor, a white round connector. If you unplug it the fans will run all the time (or should).
ALEXPR82
yep, fan did run as soon as ignition was turned but engine overheated.Opened up the air valve and there was no thermostat AT ALL. Put in new thermostat and hose and thermostat housing was bone dry. Changed hose, installed new thermostat and gasket. Replaced coolant because it was empty and car seems fine.
MMPRINCE4000
  • 8,548 POSTS
Check for leaks, the antifreeze had to go somewhere.
If you have to, get the cooling system pressure tested.
I also have to tell that, owning a 91 myself, it MAY be the waterpump is on its last leg, especially if it is the original one. Look at the weep hole in the WP for signs of coolant.
