1991 Toyota Corolla Radiator Cleaning
EDLOVER
Engine Cooling problem
1991 Toyota Corolla Front Wheel Drive Automatic 32030 miles
How do we clean the radiator? The holes are clogged and it is boiling up.
Jan 3, 2010 at 11:08 PM
MMPRINCE4000
  • 8,548 POSTS
Pour a cooling system flush in radiator, run a few minutes (accoring to instructions), then flush system with water.
If radiator is clogged up bad enough, I would replace it, they cost about $130.00.
You can also take to radiator repair shop and have it cleaned and side tanks replaced for $70 or so.
Jan 4, 2010 at 12:44 AM
