1991 Toyota Corolla Overheating
KEONSOLOMON
Engine Cooling problem
1991 Toyota Corolla 4 cyl Front Wheel Drive Automatic
What are the causes for overheating?
May 7, 2008 at 4:40 AM
TOYOTA59
The most likely causes are , low on coolant , A stuck thermostat , bad water pump , a broke water pump belt , collapsed hose , clogged radiator , fan not working , a coolant leak somewhere,
May 7, 2008 at 5:01 AM
