1991 Toyota Corolla OVER HEATING
157,000 MILES • 4 CYL • AWD • AUTOMATIC
RICHIEHN2
Hi, My car started overheating because i had a cracked radiator.I replace the thermostat and a brand new radiator.Car is still overheating the fans do not turn on unless i turn the a/c on.Can you help.
Feb 15, 2010 at 2:39 AM
MMPRINCE4000
  • 8,548 POSTS
Unplug fan switch (directly under dist.), turn ign. to on and fans should run, if they do, fan switch is bad.
If not, then relay or "engine main" relay.
Feb 16, 2010 at 8:01 AM
