Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
Corolla
Engine Cooling
Cooling Fan
Replace/Remove
1991 Toyota Corolla my car
1991 TOYOTA COROLLA
155,000 MILES • 4 CYL • 4WD • AUTOMATIC
ELEAZAR
MEMBER
the radiator fan in my car never turns off and i want to find out what sensor i have to replace
Aug 12, 2010 at 1:37 PM
MMPRINCE4000
Experienced Mechanic
It is either a stuck relay or a fan switch. Fan switch is under distribuor in coolant distribution block, has a white connector (round).
It may be as simple as plugging the fan switch back in, it may be loose. It will (if unplugged) run fans all the time.
Aug 13, 2010 at 1:21 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Check engine light
