1991 Toyota Corolla Low Beam Lights
294,000 MILES • 4 CYL • 2WD • MANUAL
GIAVANA
How do I repair my headlights. The low beams do not work only the high beams. I replaced the bulbs but the low beams still do not work. The turning signal lights and the parking lights work. Thank you for you assistance.
Nov 4, 2009 at 4:49 AM
BLUELIGHTNIN6
  • 16,542 POSTS
check the headlamp relays (if equipped) . if relays are OK or not equipped then suspect faulty headlamp switch.
Nov 4, 2009 at 7:36 AM
