1991 Toyota Corolla LOCKED GEAR SHIFT
265,000 MILES • 4 CYL • 2WD • AUTOMATIC
BJ FREEMAN
The brake petal has to be engaged to move the gear shifter from park to reverse but the button on the gear shifter will not depress to release the gear shifter so it can shift to different positions. Is there a release intergrated to the brake petal
Feb 2, 2009 at 11:30 AM
  • 75,988 POSTS
You have a problem within the shift interlock system could be the shiftlock computer or the shift lock solenoid or brake circuit
Feb 2, 2009 at 3:30 PM
