HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Toyota
Corolla
Engine
Symptoms
Overheat
SPONSORED LINKS
1991 Toyota Corolla Location
CRYFORWOLF
MEMBER
1991 TOYOTA COROLLA
Engine Cooling problem
1991 Toyota Corolla 4 cyl Front Wheel Drive 89000 miles
I am trying to locate the auxillary fan switch on a 91 toyota corolla. Can you tell me where it is located? Thanks
Monday, February 1st, 2010 AT 10:21 AM
MMPRINCE4000
MECHANIC
Fan switch is directly under distributor cap. Follow lower hose to coolant housing, switch is white one wire connector.
SPONSORED LINKS
Tuesday, February 2nd, 2010 AT 8:23 AM
Please
login
or
register
to post a reply.
Related Engine Overheat Content
1991 Toyota Corolla Water In The Radiator Boils And...
Engine Cooling Problem 1991 Toyota Corolla Two Wheel Drive Manual 86k Miles Recently, I Have Replaced Myself A Hose Pipe That Is...
Asked by
mamun
1991
TOYOTA COROLLA
VIDEO
Is Your Engine Cool Enough to Check?
Instructional repair video
GUIDE
Overheating Symptoms
An overheating engine is never a good thing to have happen. If the problem is caught quickly you can save the headache of a major engine repair. Knowing the information from...
1991 Toyota Corolla Radiator Overheating
Hi, I'm Hoping Someone Can Help Me With This Problem. F-9ik7or The Past Few Days I've Been Having Problems With A Coolant Leak And...
Asked by
toyota495
1991
TOYOTA COROLLA
1991 Toyota Corolla My Family Car Still Overheats?
I Change My Water Pump & Hoses Of The Radiator Also I Flush & Vacuum The Upper & Lower Hose Area Also At The Water Pump Area For Any Debris...
Asked by
MichaelLSJ
1991
TOYOTA COROLLA
1991 Toyota Corolla Overheating
Engine Cooling Problem 1991 Toyota Corolla 4 Cyl Front Wheel Drive Automatic What Are The Causes For Overheating?
Asked by
Keonsolomon
1 ANSWER
1991
TOYOTA COROLLA
1991 Toyota Corolla Overheated
Engine Cooling Problem 1991 Toyota Corolla 4 Cyl Manual 13500 Miles I Was Driving My Car From Bunbury To Perth (approx 150 Kms) And...
Asked by
astaniland
1 ANSWER
1991
TOYOTA COROLLA
VIEW MORE
SPONSORED LINKS
Coolant Leak Repair
Online car repair manuals
