1991 Toyota Corolla Knocking noise on front left wheel when
BPCOR1
  • 1991 TOYOTA COROLLA
Noises problem
1991 Toyota Corolla Engine Size unknown Front Wheel Drive Manual 270 miles
G'day, appreciate the service lots.
Had CV replaced bout 3-4 years ago. Does not occur when turning specifically, but feels like is rubbing. Possibly, brake fluid?
Any way to test if it is CV? Is it possible engine or mechanically. Is not a loud knocking and runs with or with out accelerator depressed.
Any tips?
Thanks.
Sunday, March 9th, 2008 AT 4:24 AM
SERVICE WRITER
  • 9,123 POSTS
Try to make a hard turn after at aout 20 miles an hour in front of someone standing on the outside and listening. This sounds like a possible wheel bearing issue. Typically the bearing will give a hum noise that may change in pitch when turning, but have also heard bad one that click intermitanttly, but most pronounced on a turn as I described.
Sunday, March 9th, 2008 AT 5:48 AM
