1991 Toyota Corolla ignotor & pick up coil test|
PITO SOTO
Electrical problem
1991 Toyota Corolla 4 cyl Front Wheel Drive Automatic
How do you test and ignitor & pick up coil to identify a fault. What should I use. And what should the readings be.
Note: Checked with an ODB1 scnner and it gave a 13 code error.
Car starts, but RPMs do not increase above 1000 and emitts black smoke.
Please advise.
Thanks
Pito
Mar 16, 2009 at 7:49 AM
MMPRINCE4000
  • 8,548 POSTS
Most autoparts stores can test the ign.module. The problem lies with either the dist. or ECM.
If module is bad you can buy a reman'd dist. w/module for less than the cost of module alone.
Mar 17, 2009 at 12:22 AM
