1991 Toyota Corolla how to take ignition out
1991 TOYOTA COROLLA
JAXBCHGIRL
Engine Mechanical problem
1991 Toyota Corolla 4 cyl Front Wheel Drive Automatic
I have my key broke off and stuck in ignition, i tried everything how do i take the ignition out
May 18, 2009 at 5:02 AM
MMPRINCE4000
  • 8,548 POSTS
You remove the lower portion of dash, below steering wheel. This will expose ign. switch. Disconnect neg. battery cable.
Turn key to assy. while inserting a small pin in hole. Ign. switch will pull straight out.
If you want, take to a locksmith and they can do it.
May 18, 2009 at 10:48 AM
