How can I turn off the radiator fan. As soon as I turn on the ednishion the fan turns on what do you think is rong with it I know its not the fan sensore and cooler sensore also the fan switch sensor and the relay becuase I already changed it what do you supose it could be pls write back a as soon as possible. Thank you.
it should only turn on when the car is heated and turn off as soon as it cools off but I does not!
SPONSORED LINKS
Tuesday, August 17th, 2010 AT 6:35 PM
