1991 Toyota Corolla fuel injectors
266,000 MILES • 4 CYL • FWD • MANUAL
CRAIGNIKI
  • 5 POSTS
hi there you guys do a good job my car when i ride it rides fine but when i keep the acelarator in to a cretain degree then the car does not go faster almost like its not geting enuf fuel what i want to know if my injectors a dirty and should they be cleaned and is this expensive ,and another thing is that i drive my car alot on reserve .pls reply this is urgent
Apr 23, 2008 at 11:36 PM
  • 31,937 POSTS
Hi there,
Change the fuel filter first, and have the fuel rail pressure checked, this will give a good indication as to the condition of the injectors, if you have never had the injectors serviced , i would recommend having this done, there are a few ways of doing this, on & off car, i feel you should have the off care service done, as at the Mls done you may well been new pintals fitted.
mark (mhpautos)
Apr 24, 2008 at 12:00 AM
