1991 Toyota Corolla Cooling Fan Switch
1991 TOYOTA COROLLA
LHERRIN
Engine Cooling problem
1991 Toyota Corolla 4 cyl Front Wheel Drive Manual
Where is the Cooling Fan Switch located? I need to replace it, but can not find instructions detailing where to locate it and how to remove and replace.
Thanks
Dec 18, 2009 at 11:31 AM
MMPRINCE4000
  • 8,548 POSTS
Cooling fan switch is directlly under distributor, it is a white connector one wire. Disconnect it and fans should run whenever the ign. is on.
Dec 19, 2009 at 1:14 AM
