1990 Toyota Corolla What type?
80,000 MILES • 4 CYL • FWD • MANUAL
JACKOLSON
  • 67 POSTS
[img:0feb5ce145]http://www.2carpros.com/forum/automotive_pictures/359978_SDC10288_1.jpg[/img:0feb5ce145]
What exactly is this type of suspension? And I see the forward arm, it's slightly bent upwards, should I straighten that out?
Thanks and more power
jack
Nov 27, 2009 at 12:23 AM
KHLOW2008
  • 41,812 POSTS
Hi Jack,
Suspension used is Macpherson struts with link arms.
The radius rod tends to get bent when mistakenly used for jacking up the vehicle or when damaged by hitting potholes.
As the rod is bent, the alignment could be out causing abnormal tire wear. You need to get the alignment checked and adjusted after straightening it.
Nov 27, 2009 at 5:10 AM
JACKOLSON
  • 67 POSTS
Thanks. Now I remember sometime one mechanic jacked my car on that side and that might have bent it. Thanks.
Nov 28, 2009 at 1:20 PM
