1990 Toyota Corolla warning lights
235,000 MILES • 4 CYL • FWD • AUTOMATIC
PUPPYPETTER25
brake and battery warning lights just came on at arrival at work. Belts are intact I think. Temp did not rise in the short time before parking. I need to get home (12 mi.)
Aug 10, 2008 at 11:26 AM
2CARPRO JACK
  • 11,533 POSTS
Sounds like the alternator isnt working. Toyotas will light the brake light as well as the batt light when it isnt charging.Not sure if it will make it 12 miles or not, wouldnt take the chance
Aug 11, 2008 at 12:44 AM
MMPRINCE4000
  • 8,548 POSTS
Exactly what Jack said, the alt. is bad. Honda's will do the same thing (bat and brake) light will come on.
While you may be able to get a cheap alt. somewhere, make sure you get the exact alt. for your car, Toyota made 3 different model alternators for that year.
Aug 11, 2008 at 1:17 AM
