1990 Toyota Corolla THERMOSTAT
165,000 MILES • 4 CYL • FWD • AUTOMATIC
CHRIS33141
CAR TEMPERATURE GOES UP REALLY HIGH, BELIEVE IT IS THE THERMOSTAT THAT NEEDS TO BE CHANGED. WHERE IS IT LOCATED?
Jan 11, 2010 at 11:40 PM
BLUELIGHTNIN6
  • 16,542 POSTS
follow the lower radiator hose back to the engine and thats where the thermostat housing should be.
Jan 12, 2010 at 1:47 AM
MMPRINCE4000
  • 8,548 POSTS
On this engine it is lower hose that connects to thermostat housing directly under distributor.
Use a Toyota part and make sure the thermostat weep hole is pointing at 11:00 when installed, replace thermostat seal.
Jan 12, 2010 at 4:47 AM
