1990 Toyota Corolla Tail Lights
18,600 MILES • 4 CYL • FWD • AUTOMATIC
MITCH77
For some reason the tail lights stopped working. The brake lights work, the signals work, and the headlights work. I can't drive the car at night. Also, I don't know it the problems are conected, but the dash lights stopped working at the same time The is alot of loose wires under the dash but they have been there before this happened. Could both bulbs go at the same time? Funny coinsidence. I can't figure ot how to take off the light assembly. No screws anywhere. Help.
Thank You.
Mitch
Sep 8, 2008 at 3:46 AM
MMPRINCE4000
  • 8,548 POSTS
There are two plastic tabs at the top and bottom of the taillight assy. Squezze them and pull the assy. out. Check the bulbs and the assy. itself. If you see any black carbon, then you may have a bad ground.
If bulbs are OK then check fuses, or stalk on column.
Sep 8, 2008 at 11:08 PM
