1990 Toyota Corolla Tail Lights
MITCH77
  • 1990 TOYOTA COROLLA
  • 4 CYL
  • FWD
  • 18,600 MILES
For some reason the tail lights stopped working. The brake lights work, the signals work, and the headlights work. I can't drive the car at night. Also, I don't know it the problems are conected, but the dash lights stopped working at the same time The is alot of loose wires under the dash but they have been there before this happened. Could both bulbs go at the same time? Funny coinsidence. I can't figure ot how to take off the light assembly. No screws anywhere. Help.
Thank You.
Mitch
Monday, September 8th, 2008 AT 10:46 AM
MMPRINCE4000
  • 8,548 POSTS
There are two plastic tabs at the top and bottom of the taillight assy. Squezze them and pull the assy. Out. Check the bulbs and the assy. Itself. If you see any black carbon, then you may have a bad ground.
If bulbs are OK then check fuses, or stalk on column.
Tuesday, September 9th, 2008 AT 6:08 AM
