1990 Toyota Corolla Starter
JSB
  • 1990 TOYOTA COROLLA
  • 4 CYL
  • 26,500 MILES
I recently have been noticing that when I try to start the engine I sometimes get a click sound that does not turn the engine over. I keep trying until it starts. I just had a new battery put in a year ago and I had the parts store check the alternator. They say the starter needs to be replaced. I was wondering if this is a very hard job to do by myself? It looks like it is in a hard to get to place. Thank you for you response.
Tuesday, July 21st, 2009 AT 5:35 PM
Try remote starting it from the starter solenoid if it cranks the engine over -check the inhibitor switch, ignition switch to include the battery connections
Tuesday, July 21st, 2009 AT 5:43 PM
MMPRINCE4000
  • 8,548 POSTS
To add to what Raz said:
Best way to remove starter is from underneath. Raise car, put on stands. Remove the right side wheel, splash shields.
Disconnect negative battery cable and solenoid connection. Starter is held in place with 2 bolts, one facing right side, one facing left side.
You can have starter tested at most autoparts stores for free.
Replace with reman'ed Denso unit.
Wednesday, July 22nd, 2009 AT 8:35 AM
