1990 Toyota Corolla seat belt
124,500 MILES • 4 CYL • FWD • AUTOMATIC
JKILLIAN
Would be able to direct me in how to replace the seat belt on the drivers side also would you know the part #
Feb 15, 2010 at 8:29 AM
KHLOW2008
  • 41,812 POSTS
Hi jkillian,
Thank you for the donation.
The part # is 73220-12671-B1, listed at $ 145.61 in our database.
This is a dealer only part so you need to check with the dealer if the part # is correct as there are different suppliers. The other place that you might be able to get one would be the junk yard.
Removal.
Move seat to most forward position and flip seat dorward.
Unclip top cover of seat belt.
Remove the holding bolt ( either 17 or 189 mm hex bolt )
Unclip the center pillar panel.
Remove the safety lower holding bolt and a small screw on upper portion( if equipped) and the safety beelt assy can be removed.
Reverse order of removal.
Feb 15, 2010 at 6:46 PM
