1990 Toyota Corolla rack and pinion
LILHLOW
Steering problem
1990 Toyota Corolla 4 cyl Two Wheel Drive Automatic
what's involved in changing out the rack and pinion unit
Oct 1, 2010 at 3:53 PM
MMPRINCE4000
  • 8,548 POSTS
Removing outer tie rods and pressure/return lines. Then hold down bolts.
Problem is getting to it, engine and lower cradle are in the way.
You can remove intake manifold for better access.
Oct 2, 2010 at 1:49 AM
