1990 Toyota Corolla noise underneath when i excel to 40 to
NUTSYBUMPO12
1990 Toyota Corolla 6 cyl Automatic
about a week ago i noticed when i picked up speed in my toyota approximately 40 to 50 mph i hear a noise-underneath the car. i feel it when i go faster,
no fluid is leaking out. the steering is a bit off. what can it be?
Sep 30, 2009 at 9:50 AM
MMPRINCE4000
  • 8,548 POSTS
Check the transmission fluid.
Check the differential fluid.
Check power steering level and rack for leaks.
Raise car, put on stands. Grasp tire and push/pull both horizontally and vertically, if any movement then possible wheel bearing, ball joint, tie rod, control arm bushing.
Check CV boots for any signs of leakage or cuts/rips in rubber boot.
Oct 1, 2009 at 3:06 AM
