1990 Toyota Corolla misses when warm
JUSTINSIVICH
Engine Performance problem
1990 Toyota Corolla 4 cyl Two Wheel Drive Automatic 230k miles
my car starts to miss and slow on acceleration when it warms up it is a 1990 corolla we replaced spark plugs distributor 02 sensor throttle position sensor fuel filter and still no fix
Jul 23, 2010 at 6:43 AM
  • 75,988 POSTS
Possibilities: Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it.
Jul 23, 2010 at 4:41 PM
