HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Toyota
Corolla
Engine
Symptoms
Revs Up
1990 Toyota Corolla Low RPM Torque
JACKOLSON
MEMBER
1990 TOYOTA COROLLA
4 CYL
FWD
MANUAL
85,000 MILES
How do you tune an engine to get the max torque possible at the lowest reasonable rpm (like in a rally car)?
Sunday, January 24th, 2010 AT 11:28 AM
MMPRINCE4000
MECHANIC
It's a combination of head, intake, camshaft, exhaust, timing and exhaust.
You can only really tune the timing and to some extent the fuel.
But more power requires more air.
SPONSORED LINKS
Monday, January 25th, 2010 AT 8:32 AM
Please
login
or
register
to post a reply.
Related Engine Revs Up Content
1990 Toyota Corolla Idling Rev
Hi Guys, When I Start My Engine From An Overnight Parking, The Engine Will Set At 500rpm Idling Rev. Then After 15 Minutes It Will Rise...
Asked by
jackolson
1990
TOYOTA COROLLA
GUIDE
Idle Air Control Motor Replacement
The idle air control motor or idle speed control motor is designed to adjust the air flow into the intake manifold at engine idle. Engine idle speed is monitored by the PCM...
1990 Toyota Corolla Low Rpm
When Activate The Ac Unit The Car Rpm Goes Down To Mush Causing The Car To Shut Down In Addle And The Voltage Goes Further Down Than 12.75...
Asked by
Fred Perez
1990
TOYOTA COROLLA
Car Starting But Not Revving
The Engine Will Idle But When You Depress Throttle It Rev To About 2000 Rpm Then Cuts Out. The Computer Puts Up A Fault Code P0120 Which Is...
Asked by
vintagefeetup
1997
TOYOTA COROLLA
Car Revs High When Ignition Is First Turned On
When The Ignition Is Turned On The Car Revs High. Once It Revved So High The Engine Turned Off Instantly. Recently, After I Had Driven To...
Asked by
DelR
2003
TOYOTA COROLLA
2009 Toyota Corolla Engine Test - Revving
I Had An Issue With Cruise Control In My Car. I Was Driving About 60 In Cruise Control And Didn't Realize That You Needed To Manually Shut...
Asked by
tommy7777
2009
TOYOTA COROLLA
VIEW MORE
SPONSORED LINKS
Vacuum Leak
Vacuum Leak Test and Repair
Online car repair manuals
