Do as Raz suggested. If problem persists, idle is adjustable on these engines, but make sure it is not the IAC before adjusting idle.
Idle is adjusted with ECM in field service mode, using the idle adjusting screw.
SPONSORED LINKS
Thursday, August 13th, 2009 AT 8:15 AM
