1990 Toyota Corolla loss of battery power
159,000 MILES • 4 CYL • FWD • AUTOMATIC
BALSIZER
i just replaced the battery, drove car for the day, parked for the night and the battery was dead the next moring. recharged the battery and checked the alternater which is perfroming correctly. however again used the vehicle for day and the next moring the batttery was dead. Each day when i start the car cold the battery and brake dash lights appear, go off when brake pedals is depressed only after the car has been engaged and moved. Once car engine is warm, the lights go off and remain off even after restarting. I have no blown fuses. In addtion the over head dome light only works in the "ON" switch position, no light when in the "Door" switch position either when engine is on or off.
Where do i go to resolve the dispearing power from the battery? I would like to have some dependablity from the car as know i am removing the battery cable when i park the car.
May 16, 2010 at 1:33 AM
MMPRINCE4000
  • 8,548 POSTS
Take to autoparts store and have charging system tested, including battery, alt, starter draw and drain test.
If, by disconnecting the negative battery cable, the battery is OK, then there is a drain on it.
Hook up DVOM to battery and remove fuses one at a time while watching DVOM volts, until you isolate the drain circuit.
I would still go have battery/charging test first.
May 16, 2010 at 1:41 AM
