1990 Toyota Corolla Key won't turn
325,000 MILES • 4 CYL • FWD • AUTOMATIC
PRPLT
I put the key into the ignition switch and have to jiggle it around to get it to turn and allow the car to start. What part needs replaced? Is it labor intensive? Thank you so much for your time and attention.
Jun 2, 2008 at 6:21 AM
KHLOW2008
  • 41,812 POSTS
hi PrplT,
The key cylinder is worn. A locksmith might be able to salvage it but if the wear is too bad, then you need to replace it.
Replacement should take abut half an hour. Repair maybe an hour.
Costwise I am unable to help you.
Jun 2, 2008 at 6:33 AM
