1990 Toyota Corolla gas
1990 TOYOTA COROLLA
85,000 MILES • 4 CYL • FWD • MANUAL
JACKOLSON
  • 67 POSTS
will it be okay to use Regular Gasoline to a 20-year old engine? I got used to using Petron XCS but now it has E-10, and my carb is giving in. So i decided to use non-E10 gas which is the Regular Gas only.
will it harm the engine or will it be better?
i mean, the engine was made by the time there were there are no special gasolines like shell velocity, v-power, petron xcs and blaze
Feb 14, 2010 at 4:22 AM
MMPRINCE4000
  • 8,548 POSTS
Most cars built from the mid 80's were designed to run on 10% alcohol.
With a carb, I would probably run straight gas, if you had FI, then run the 10%.
FI can compensate for the increased fuel requirements, better than a carb.
One thing you DO NOT want to run is methanol, it can cause harm to engine.
Feb 14, 2010 at 11:51 PM
