1990 Toyota Corolla Fuel tank
15,500 MILES • 4 CYL • FWD • MANUAL
RAMNPT
Fuel tank is being over pressurized causing a slight fuel smell. when removing the gas cap (slowly of cource) it takes a very long time to stop hissing (much much longer than normal)
Oct 6, 2010 at 1:11 AM
MMPRINCE4000
  • 8,548 POSTS
There is a smaller vent hose, make sure it is not clogged.
Also check the charcoal cannister connections and a bi-metal vacuum valve. It has two vacuum lines, they can break off.
Oct 6, 2010 at 1:43 AM
