where is the fuel pump located on a 1990 toyota corolla?
HARVEL
Feb 3, 2009 at 4:45 AM
ZACKMAN
  • 4,202 POSTS
The fuel pump is inside the gas tank here is how to change it out. Check out the images (below). Let us know if you need anything else.
Feb 3, 2009 at 7:08 AM
MMPRINCE4000
  • 8,548 POSTS
Before you write off the pump, short B+ and Fp pins on the diagnostic port. If pump runs, then the problem is a relay/fuse/wiring.
If pump does not run, then pump is bad.
Feb 3, 2009 at 9:33 AM
ZACKMAN
  • 4,202 POSTS
I agree..
Feb 3, 2009 at 6:44 PM
