1990 Toyota Corolla Fuel delivery
23,000 MILES • 4 CYL • FWD • MANUAL
PENNZERO
I have a hard time starting the car in the mornings. It will never start on the first try instead it will start after the second or third try. Then after it is started I seem to have a loss of low end torque. Also when I turn on the air conditioning the idle nearly stalls all the way out dropping to 500 or so RPMs.
May 8, 2008 at 10:01 AM
  • 75,988 POSTS
Inspect and test the coolant temperature and throttle position sensors/idle air control valve
May 8, 2008 at 10:19 AM
PENNZERO
[quote:d84a205515="rasmataz"]Inspect and test the coolant temperature and throttle position sensors/idle air control valve[/quote:d84a205515] Thanx
May 8, 2008 at 1:47 PM
