because a/c takes more power to run it. try cleaning throttle plate on both sides and iac hole with choke cleaner see if that takes care of it
Jan 24, 2016 at 2:44 AM
MARIOC68
MEMBER
I had already done that a few days ago but makes no effect. When the A / C is off smoothly all is well.
Jan 24, 2016 at 2:51 AM
✓Experienced Mechanic
There should be an idle up for the A/C normally should be a vacuum switch that bypasses the throttle plate with the a/C on to idle up and help maintain a smooth idle
Jan 24, 2016 at 4:43 AM
MARIOC68
MEMBER
TPS is normal that produce noise as hits such as tic tic tic ... sometimes?
could be in need of a valve adjustment as I hear a lot of clacking goin on in video or sticky valves which I doubt or worn valve guides. due to mileage it could be any of those
Mar 6, 2016 at 3:02 AM
MARIOC68
MEMBER
Without a / c on, idle and then accelerating a bit and then releasing the accelerator:
IAC has any effect the control valve when idle when the A / C is turned on?
Mar 17, 2016 at 12:55 AM
HMAC300
everything yu are showing on vacuum gauges are normal have you even tried adjusting valves or still questioning what we have suggested. I have no further comments.
Mar 17, 2016 at 2:26 AM
MARIOC68
MEMBER
I managed to repair the unstable idling.
The thermistor a / c each as active time on and off the compressor ?. Mine does about every 10 seconds.
Mar 26, 2016 at 1:59 PM
Hi I have seen this problem before and never found out what was wrong did you get the problem resolved?
