1990 Toyota Corolla engine
JOELCARIAGA
  • 1990 TOYOTA COROLLA
  • 4 CYL
  • FWD
  • MANUAL
  • 206,437 MILES
When I was driving for 70 mph on 3rd gear I was going to change gear 4 but it went to 2nd gear then the car engine just shut down and I know I did not blew the engine and I change distrubutor module and still nothing can someone help me!
Sunday, June 20th, 2010 AT 3:20 PM
Does it crank over and will not start or just won't crank at all/nothing?
Sunday, June 20th, 2010 AT 4:12 PM
JOELCARIAGA
  • 6 POSTS
Yeah its cranking and I follow the firing code on the book
Sunday, June 20th, 2010 AT 4:56 PM
Do below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, cap and rotor, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Sunday, June 20th, 2010 AT 4:57 PM
JOELCARIAGA
  • 6 POSTS
Well I change the ignition control module too and I check the sparks yeah it does have blue spark but when I start it again I heard a sound like a nos and I change the engine relay too
Sunday, June 20th, 2010 AT 5:15 PM
Check the fuel pressure with a gauge to rule out the fuel pump if okay check the valve and ignition timing
Sunday, June 20th, 2010 AT 5:19 PM
JOELCARIAGA
  • 6 POSTS
Thank you
Sunday, June 20th, 2010 AT 5:23 PM
JOELCARIAGA
  • 6 POSTS
Well now the is cranking and starting for a few sec. Then engine stalls and it won't continue. Can someone help me please.
Tuesday, June 29th, 2010 AT 1:40 AM
Related Engine Stall While Driving Content
Is it Safe to Drive Check Engine Light?
VIDEO
