1990 Toyota Corolla 4 cyl Front Wheel Drive Automatic 87, 8OO miles
my friend worked on my car. He drained the trans fluid instead of the oil and put another 5 quarts in to the engine, which caused it to run funny I drove home and was being followed by clouds of smoke coming out of the muffler. Problem now is I have a problem starting it when I turn it on after a minute it starts revving up by itself therefore increasing and decreasing rpm speeds when I stop at a light this continues sometimes the car shuts off in the middle of the street! He also changed the spark plugs I drained the excess oil and added the neccesary trans fluid but now it turns off and revs itself please help!
PS
WOULD THE EXTRA OIL HAVE DAMAGED THE GAS LINE OR SHOULD I TRY REPLACING THE SPARK PLUGS?
THANK YOU I APPRECIATE YOUR TIME IN READING THIS AND YOUR USEFULL KNOWLEDGE
Tuesday, May 6th, 2008 AT 7:26 PM
